Page 1 of 2
Rolling Chassis
Posted: Tue Aug 16, 2011 8:50 pm
by soulsurfer
Just sitting on my arse thinking " what's next to do?", as you do, and wonder what's the minimum needed in the engine casing to give a rolling rear wheel to a frame?
Engine mounts, rear hub bearing, layshaft, endplate & bearing(?), hub & rim, git the front end covered, but anything else needed or not needed for a rolling chassis at the back end?
Re: Rolling Chassis
Posted: Tue Aug 16, 2011 9:32 pm
by CPH Lambretta
Rear damper
Re: Rolling Chassis
Posted: Tue Aug 16, 2011 9:39 pm
by byron
as I often have engine-less bikes around, and need to shuffle them about, I made a frame up out of some bits of square section, welded some bits of a cut about shock, an engine bolt and a front axle, and fitted an old front hub...
Re: Rolling Chassis
Posted: Tue Aug 16, 2011 9:53 pm
by RICSPEED
you pretty much covered it mike less the rear shock as said
Re: Rolling Chassis
Posted: Tue Aug 16, 2011 10:03 pm
by soulsurfer
RICSPEED wrote:you pretty much covered it mike less the rear shock as said
Which reminds me, I must take the old shock out of the scrap bin for this purpose. It needs to have the correct ride height to check for side stand mounting on the frame.
Re: Rolling Chassis
Posted: Tue Aug 16, 2011 10:13 pm
by RICSPEED
a good scrap bin is never empted
Re: Rolling Chassis
Posted: Wed Aug 17, 2011 8:20 am
by Dazza
Rear tyre :anbrgin;
Re: Rolling Chassis
Posted: Wed Aug 17, 2011 8:37 pm
by soulsurfer
byron wrote:as I often have engine-less bikes around, and need to shuffle them about, I made a frame up out of some bits of square section, welded some bits of a cut about shock, an engine bolt and a front axle, and fitted an old front hub...
Found this whilst surfing...
Re: Rolling Chassis
Posted: Wed Aug 17, 2011 8:39 pm
by RICSPEED
that is byrons ...i assume you knew that though
Re: Rolling Chassis
Posted: Wed Aug 17, 2011 8:54 pm
by soulsurfer
RICSPEED wrote:that is byrons ...i assume you knew that though
