Page 1 of 9
barlow stage four set ups
Posted: Tue Aug 16, 2011 4:39 pm
by C*NTSPEED
well folks what set ups are you running ie main jet and pipe also the timing am i right that they run around the 18 deg ?
Re: barlow stage four set ups
Posted: Tue Aug 16, 2011 6:09 pm
by H,POOL GADGE
1.7 packer - 12.5 squish - 14cc head volume - 123 main - 2.8 idle T5 slide cosa cap and carb supply hole drilled - 18 deg - augusta 6000 - jL R/hander
Posted: Tue Aug 16, 2011 6:33 pm
by sean brady scooters
12.5 mm squish
Posted: Tue Aug 16, 2011 7:52 pm
by H,POOL GADGE
give or take .5 then! ...what do ye think about lifting the top of the exhaust port 1mm gadge(sean) it would help lower compression, but would you have to rev the scoot harder to get it going....
Posted: Tue Aug 16, 2011 10:59 pm
by Juan
Can the spark jump 12 mil then?
I'll hazard a guess the decimal point may have a slipped a point.
Posted: Tue Aug 16, 2011 11:05 pm
by H,POOL GADGE
Ha Ha Ha! Oooops....1.25mm be no good at morse code would'a
Posted: Wed Aug 24, 2011 7:07 pm
by C*NTSPEED
whats the recomended ring gap?
Posted: Wed Aug 24, 2011 7:15 pm
well i,d go for 0.3mm/0.35mm...but no doubt H/poolgadge would say 3.5mm
Posted: Wed Aug 24, 2011 8:50 pm
by H,POOL GADGE
-.-- --- ..- .-- . .-.. .-.. --- ...- . .-. -.. ..- . .- ...- .. ... .. - -.-- --- ..- -. --. -- .- -. -.-. .... . . -.- -.-- .-.-.- .-.-.- .-.-.- laughing at an old man and his decimal points! work that out then......
Posted: Wed Aug 24, 2011 9:18 pm
by Muttley McLadd
