R1 Shock
Posted: Fri Aug 12, 2011 10:39 pm
by Norris1977
Hello does anybody know how to adjust an R 1 shock for correct set up? thanks
Re: R1 Shock
Posted: Fri Aug 12, 2011 10:46 pm
by Andy Pickering
You will need the special tool sold with them..
Re: R1 Shock
Posted: Fri Aug 12, 2011 10:55 pm
by Chutney Brownlove
Lam46 wrote:You will need the special tool sold with them..
Or use a large pipe wrench, Stilsons etc. Like I do.
Re: R1 Shock
Posted: Fri Aug 12, 2011 10:58 pm
by Andy Pickering
Chutney Brownlove wrote:Lam46 wrote:You will need the special tool sold with them..
lol
Re: R1 Shock
Posted: Fri Aug 12, 2011 11:04 pm
by Norris1977
I have the spanner but am not sure what setting it needs to be on, same as the 2 adjuster screws not sure witch click they sould be on.
Re: R1 Shock
Posted: Fri Aug 12, 2011 11:09 pm
by Muttley McLadd
There's no 'set' setting. It'll depend on a variety of factors like: your weight, what riding you do, etc.
PB does suspension set ups on bikes most months. Although they're not going to tell you how to set up an R1 shock on a Lambretta, there's clues enough to give you a heads up on how to do it.
Re: R1 Shock
Posted: Fri Aug 12, 2011 11:11 pm
by RICSPEED
i think the rebound adjuster is best left alone ...the preload is up to you ...whether you carry (passenger ,luggage etc)
start on the softest and see
Re: R1 Shock
Posted: Fri Aug 12, 2011 11:44 pm
by Andy Pickering
What is it exactly your want.to do with the set up Norris , lift it lower it..?
Re: R1 Shock
Posted: Sat Aug 13, 2011 12:58 am
by lifes a drag
just google it ,,,, its all on there ,
bump re bound stiffness ,, its all down to personal choice,,
scooters aint as set up able as bikes so dont expect wonders but if you play about with the settings
it will make a difference
