Help with electronic conversion
Posted: Fri Aug 12, 2011 5:59 pm
I’m stuck! Hopefully someone on here witth a brain can help me out
I’m trying to do an electronic 12 v conversion on a Vega
So far I have mounted a Pk stator on to a Vega stator plate and removed a Vega flywheel boss to mount on to a AF Rayspeed lightened flywheel.
What I need to know is at what position do I mount the Vega boss to the AF flywheel so that the s shaped magnets which cause the pick up to fire are in the right location in relation to the keyway in boss.
I have some information from another forum where this has been found by
I have marked where the keyway was on the af flywheel before I removed its original boss. Would it be in the same place?
I don’t have a points based flywheel to allow me to follow this advice. Any other suggestions?joeyfont wrote:...forget about where all the bits used to go....
what i did was found the keyway position when the points started to open = 11 o'clock before tdc
put the boss on crank,then line the electronic flywheel up with pickup timing mark,bolt flywheel to boss... :no: :study: :scratch::affraid:
