Page 1 of 2
Advantages of hole in side panel?
Posted: Fri Aug 05, 2011 11:33 pm
by Norris1977
Hello. I am running a ts1 with a 34 delorto. Can any body tell me what the advantages are of cutting a hole into the side panel?
Re: Advantages of hole in side panel?
Posted: Fri Aug 05, 2011 11:42 pm
by sydduckett
Norris1977 wrote:Hello. I am running a ts1 with a 34 delorto. Can any body tell me what the advantages are of cutting a hole into the side panel?
It allows you to get a clean air flow into the carb. Im presuming that having a ts and 34 carb you like to give it some, if you do then this helps apparantley...
Posted: Sat Aug 06, 2011 12:04 am
by sean brady scooters
a hole in your panel not only lets more air in and more efficiently but its the fact thats its also colder or at least cooler air than would otherwise be aspirated from under your panels or through a filter or both ..
Posted: Sat Aug 06, 2011 7:08 am
by Craig H
makes your foot smell of oil/petrol hmmmmmmmmm
Posted: Sat Aug 06, 2011 7:12 am
by Muttley McLadd
Alternatively, knock a bulge in your panel where the carb is for a bit more clearance, and drill a few holes towards the front of the panel to let air in.
Posted: Sat Aug 06, 2011 8:30 am
by camel
so you can have a ram air filter sticking out
Posted: Sat Aug 06, 2011 2:22 pm
by soosh
Run like f@@k down the road for a mile with your hand over your mouth.That's how an obstructive carb feels.
Posted: Sat Aug 06, 2011 3:37 pm
by mawso
^^ Ha!
Posted: Sun Aug 07, 2011 8:37 am
by soosh
soosh wrote:Run like f@@k down the road for a mile with your hand over your mouth.That's how an obstructed carb feels.
Posted: Sun Aug 07, 2011 8:23 pm
by Norris1977
Thanks for the advice, Next question lol whats the easiest way to cut the hole?
