Page 1 of 2
Imola timing help.
Posted: Fri Aug 05, 2011 11:06 pm
by jaymarriott
Evening all,
Is there any personal recomendations regarding what degree's to set the timing on my Imola kitted engine, I've read 18 degree's, but been told to run it at 16 instead.
Any help would be greatfull accepted.
Cheers.
Re: Imola timing help.
Posted: Fri Aug 05, 2011 11:55 pm
by sjc
run mine at 18 degrees..
Posted: Sat Aug 06, 2011 12:36 am
by jaymarriott
sjc wrote:run mine at 18 degrees..
Mines at 18 degrees. What is the rest of your set up?
I take it you have no problems with your mate.
Cheers.
Posted: Sat Aug 06, 2011 9:40 am
by 10 inch Terror
I also run mine at 18 degrees.
Posted: Sat Aug 06, 2011 11:40 am
by coaster
jaymarriott wrote:Evening all,
Cheers.
The issue of retarding the ignition timming applies to all tuned scoots, not just Imolas. 17 or 18 degrees should be fine for shortish blats but for all day motorway blasts at full throttle, it is safer to retard slightly and hopefully avoid the risk of holing a piston. The down side is a slight reduction in peak hp
Posted: Sat Aug 06, 2011 11:49 am
by jaymarriott
Ok, thanks for that, it's ok to run it at 18 degrees, now to set my carb up
Posted: Sat Aug 06, 2011 12:24 pm
by rocho68
mines set at 16 degrees
jaymarriott wrote:Ok, thanks for that, it's ok to run it at 18 degrees, now to set my carb up
Posted: Sat Aug 06, 2011 9:35 pm
by jaymarriott
rocho68 wrote:mines set at 16 degrees
AAAAGHHHH
how is it running, what set up are you using and your riding style?
Posted: Sun Aug 07, 2011 10:50 am
by rocho68
jaymarriott wrote:rocho68 wrote:mines set at 16 degrees
AAAAGHHHH
its runnig a jl4 , 30 delloto , fully tuned making just under 25bhp , runs beautiful , no probs at all
Posted: Thu Aug 11, 2011 8:36 pm
by psychedelicropcircle
I'm at 17 btdc 28mm dellorto 52 pilot 120 main 45 slide x2 needle. Ancellotti clubby. Had a 115 main 50 pilot with a cut up S1 cowling that holed two pistons.
changed the base gasket to copper to up my squish also.
HTH
