Dellorto SI26 -any good?
Posted: Sun Jul 31, 2011 7:12 pm
by Svint1
Gents,
I'm currently using a PHBH30 on my 60mm longstroke Polini208 engine. The exhaust is PEP2, but a Sip Road arriving next days..
I think it might is a overkill with 30mm (and the induction noise kills me!), so I'm thinking of a Dellorto SI24 or 26.
Had a SI24 some years ago, but it didn't cool the engine enough, so had some heat-seizures on long motorway trips.
-thought then that a SI26 would be better?
But does anyone know of the quality of the Dellorto SI26 carbs?
And how would it be to jet it for my engine?
Rgrds,
Øyvind
Re: Dellorto SI26 -any good?
Posted: Sun Jul 31, 2011 8:52 pm
by sean brady scooters
its nothing to do with the bore size of the carb that cools your scoot and prevents siezes its the jetting /setting up
Posted: Sun Jul 31, 2011 9:37 pm
by Svint1
sean brady scooters wrote:its nothing to do with the bore size of the carb that cools your scoot and prevents siezes its the jetting /setting up
OK, but I read somewhere that the SI carbs was no good of cooling engines, due to the "short" manifold, meaning a PHBH with a Malossi or polini inlet manifold, would cool better.
True or false?
But if a SI is good enough, fine with me!
But how should I then jet a SI carb?
Setup is as mentioned above, and the casings are mildly ported to the sylinder, but nothing in the inlet.
Rgrds,
Ø
Posted: Wed Aug 03, 2011 6:54 pm
by gaz_powell
24 or 26 will be suitable as long as it is jetted correctly
would imagine 140/be3/132 then come down on the main and up the pilot by slightly should be a good start
i`ve used both and found no difference with the 26 over the 24 both were spaco
