238cc clasic rapido with dev tour and TM24 + FILTER
Posted: Fri Jul 22, 2011 5:30 pm
71mm revtour piston(ts1 windows) classic rapido barrel, 60mm mec crank, Mikuni TM24 + ram air filter in toolbox, LTH German reed manifold. indian ign +vespa black box and coil.strobed at 2mm btdc.(18 degs) runs Li125 19x47 set up. Dev tour system
16.65 hp /13.6 ft lbs of torque with a wide spread. 5N13 needle 2nd clip down, 20 pilot 1.5 turns out, 230 main jet
Runs strong and is good on fuel. will be at shipston rally.
