Opinions needed
On the way to this years Euro in Kilarney the screw came out of my pickup and destroyed my stator. Luckily I had a spare but no means of timing it in. I deliberately set it on the retarded side to play safe as I had Mark Tidd on the back and a fekin long way to go :shocking:
Anyway, the scoot was a bit sluggish but would pickup and then start 4 stroking at about 3/4 throttle in all gears (with Mark on the back I didn't achieve that in 4th ;) ). I've not changed anything since we got back and have just been out to the shops (8 mile run) on it and managed to get it to 4 stroke flat out in 4th at 65mph(Garmin). On leaving to come back it wouldn't fire up as normal but did run on the choke until I turned it off at which point the engine died and wouldn't fire up with or without the choke. Took the plug out which was quite black and messy so stuck a new one in and it fired up straight away. Now for the strange bit, the 4 stroking has completely gone :? I actually saw just over 65mph in 3rd on the way back :shock: its never done that before, 60 mph was the best I had doing some carb fine tuning on the morning I left for Ireland. Just wish the road had been clearer so I could have seen what it would do in 4th ;)
Is it likely that a plug would do this or have I developed an air leak :?
    Users browsing this forum: Google Adsense [Bot] and 6 guests
