LI panel on GP ( well spanish clip on type)
Posted: Sun Jul 17, 2011 7:05 pm
by boxofbits
making a bike out of bits i have in the garage -- i thought all gp,li,sx etc panels fitted on any bike li,gp etc
But it seems these sevetta type pannels ( clip on type) i have dont fit on this gp frame i have - different angle at the back -
i'm sure i had these panel on a gp before, any ideas
Re: LI panel on GP ( well spanish clip on type)
Posted: Mon Jul 18, 2011 9:10 am
by RICSPEED
they should fit ,something must be out on the frame ,have you any other panels you could try ?
Posted: Mon Jul 18, 2011 1:30 pm
by bristolmod
I did exactly the same a few years ago with clip on "LI" type panels on a GP150- was a good fit.
Has the GP frame had a clout in the rear??
Posted: Mon Jul 18, 2011 8:04 pm
by coaster
bristolmod wrote:Has the GP frame had a clout in the rear??
That's what I was thinking or maybe been stored/transported on end
Posted: Mon Jul 18, 2011 9:17 pm
by boxofbits
Looks like your right a think its been stored before I had it stood up it off by about 5mm will have to bend it out what's the best way car jack:-D
Posted: Mon Aug 01, 2011 10:08 pm
by koomwah
I've just tried a couple of panels on my GP and seem to have the same problem!
Is there an easy way to sort this?
Posted: Mon Aug 01, 2011 10:31 pm
by WINTERMODEL150
Hi guys,from past experience many people seem to bend the spring type hook to get a tighter side panel fit stopping the panels falling off down the road ,thus bending the rear of the frame at the same time
Dean
Posted: Tue Aug 02, 2011 12:10 am
by coaster
Bear in mind that the panel buffers play a part in pushing the bottom of the panel out which has the effect of pulling the ends in a fair bit. I would fit the rear runners and make sure the rear supports aren't bent in as well. I had a bit of trouble with my Jet getting the panels to clip on but found fitting the buffers and bending on of the supports out fixed it
