TS1 throttle cable route
Posted: Wed Jul 13, 2011 7:59 am
What's the best route for a TS1 throttle cable?
I've recently fitted a TS1 kit and run a long cable along the conventional route and then between the tank and toolbox. The gap is a bit tight because I've got a 12.5 litre tank and fuel tank buffers and straps get in the way of the most natural route. As a result the throttle seems stiff, although it does spring return OK. Would it be better to run the throttle cable through the same route as the gear and clutch cables?
Any advice gladly received
Phil
Phil
