Vespa T5 Knocing Noise??
Posted: Tue Jul 12, 2011 8:24 pm
by servetakid
My MK1 T5 has developed a knocking noise. It is coming from the rear wheel. You can feel/hear it when spinning the wheel. There is no play in the wheel, and it is like a strong tapping noise when you spin the hub back and forth. It rides well, but does any one have any idea what could be causing it?
Cheers,
Re: Vespa T5 Knocing Noise??
Posted: Tue Jul 12, 2011 9:59 pm
by smiffy1968
It might not be, but i had a noise like that and in the end it turned out to be the cush drive plates/ rivets detaching. Both plates were chewed up and sitting in the bottom of the engine casing, woops! :o
Posted: Wed Jul 13, 2011 7:34 am
by servetakid
Would something like that explain why there was a bit of oil on the bottom of the casing? And would it ride badly?
