Coil bound springs
davidblythe
have machined a crownwheel that has 30mm depth and tegether with a foxhat style spider i bought it should be able to fit 5 trad plates or 6 thin plates
the problem i have is the springs are becoming coilbound at approx 16mm which is not allowing me to fit the last cork
any ideas anyone
J1MS
Readspeed supplies a set of spring that addresses this issue give him a call....
davidblythe
many thanks
which springs were you using?
davidblythe
tried every set i have, inc taffy ones, the thin 5 plate clutches all seem to come coil bound 16 to 17mm
davidblythe
solved the issue by cutting one coil of the springs i had, unfortunately the pressure plate then hit the nut on the xmas tree
shame as still had 3mm of depth unused for the pressure plate to sit in , really needs a modified pressure plate as well to work with 5 standard plates, but can see that it is achievable
muttonjeff
david, what spider are you using.
muttonjeff
david, what spider are you using, af,uprated springs are not for use in a FOXHAT spider,use af,gt springs. also your issue with depth, we have a pressure plate to deal with that.
muttonjeff
Hi David
Seriously what spider are you using at this momant in time??? Issue- 'Foxhat Style', There is only ONE FOXHAT SPIDER. Please inform us all what a 'foxhat style' spider actually is??
Regards Art and Al- FOXHAT
is it one of those cheap copies............from the other side of the world..................
approx £30.....................?
    Users browsing this forum: Semrush [Bot] and 23 guests
