BGM voltagage regulator/rectifier and sat nav
camel
hi all,just fitted a bgm voltage regulator and the instructions say you can run a sat nav direct from the dc output,so ive wired a cigarette lighter in and plugged my sat nav to it and its gone haywire,has anyone else succesfully done this without wireing a battery between the dc output and the sat nav
lockman69
If this is the little £20 bgm jobbie, I run my tom-tom ( via lighter socket) and my MB speedo, and my Egt backlight and it all works great.
camel
yes it is.....i was hoping i would not have to put a battery on it.....
lockman69
I don't have a battery on mine, Indian flywheel and BGM 80w stator...
camel
a small capacitor borrowed from work seems to have cured it
