Page 1 of 2
Fuel Gauge
Posted: Mon Jul 11, 2011 3:10 pm
by Bilko
I have a spare hole :shock:
So I was thinking of running a fuel gauge off the battery.
Anything I should look out for or avoid?
Re: Fuel Gauge
Posted: Mon Jul 11, 2011 9:18 pm
by AUSSIE
the gauge is the easy bit, lots of different styles to choose from. its the sender in the tank that is the tricky part to find. one on ebay for a boat application that is adjustable for tank depth seems pretty good.
not sure what sender will fit in a standard tank due to restricted room
Re: Fuel Gauge
Posted: Mon Jul 11, 2011 9:27 pm
by Bilko
Thanks Aussie.
I have a Diablo tank, but I still need to watch for the anti splash plate though.
I was considering This
Re: Fuel Gauge
Posted: Mon Jul 11, 2011 10:28 pm
by mark
any help?
http://scooterotica.org/forum/viewtopic ... lit=+gauge
sender after shortening
fuel sender for lambretta by mark & anne's photos, on Flickr
a bit more weight added
fuel sender by mark & anne's photos, on Flickr
Re: Fuel Gauge
Posted: Mon Jul 11, 2011 11:03 pm
by Bilko
It is, thank you Mark.
Re: Fuel Gauge
Posted: Tue Jul 12, 2011 9:27 am
by alcoholic maniacs sc
wanting a fuel gauge fitting myself.will a px one adapt to fit.is there enough level area on the top of a standard lammy tank to fit the anchor point?
Re: Fuel Gauge
Posted: Wed Jul 13, 2011 1:49 am
by jonashford
http://www.asap-supplies.com/search/fue ... resistance
Get ur gauge and sender from here reliable and fast service faria gauge is what I use off a battery works well
Re: Fuel Gauge
Posted: Wed Jul 13, 2011 9:16 am
thanks for that mate!!bloody brilliant.ordered, i cant wait not to run out of fuel on the M1 :oops:
Re: Fuel Gauge
Posted: Wed Jul 13, 2011 10:02 am
by JDale
I have also looked at the asap website and am looking to order both a fuel gauge and sender, looking at the diptype fuel they are all different lengths by cm. Which is the correct length one to buy for a standard series 3 tank?
Thanks in advance :-)
Re: Fuel Gauge
Posted: Thu Jul 14, 2011 2:50 am
by jonashford
I dunno the exact length of the STD tank u can just put a tape down the fuel cap
And measure, I use a diablo tank with a hole cut in, flat plate welded to the tank with m5 bolts protuding to bolt down the sender, easy job for anyone with basic metalwork knowledge, hope this helps?
They do all different lengths of sender just measure ur tank and get the next shortest, u shouldn't run out then,
