Under the crankcase cover.
Posted: Thu Mar 19, 2009 1:45 pm
This one remains a puzzle, after my first posting of Kickstart Slipping, (which you may have to read for this to make sense.)
from the feedback given I can now confirm that all is 99.9% correct and working without any issues. But get this guys, I didn't find anything wrong, but did take everyone input on board even left the kickstart shaft with the engineers blue on the end!
With the case on and tightened up, the kickstart turns the motor over without any slipping whatsoever! However fit the spark plug and you have a differant outcome, one slipping kickstart, when you can get a full swing the motor starts and runs fine........Question is why?
Is the compression to high? it's only a iron 175 stage four, big bore clubman nowt special. If this could be the problem how can I lower it, without too much agro?
Do I have a problem looming elsewhere and if so can anyone shed some light on the matter, as Im stumped!
Did say I would report back my findings, just wish the problem was resolved fully!
Rick.
Rick.
