Piston travel v Crankshaft rotaion (deg BTDC)
Posted: Mon Jul 04, 2011 11:16 pm
i always set my timing using a DTi , i know (from Sticky`s bible ) that on a 58mm stroke crank with a 107mm rod 19Deg is 2.00mm . im about to fit a chiselspeed advance/retard unit and need to know what 25 deg BTDc is in mm travel, is there a formula for working this out or can anybody tell me what it is ?
Thanks in advance
Thanks in advance
