IGNITION TIMING
Posted: Thu Mar 19, 2009 12:25 am
Ignition timing, i was running a 205 Honda built by Mb back in 96 and it was set at 20 degrees everything was ok, i changed over to a classic rapido 225 with a low compression head, 24mm mikuni and a ancilotti clubman and everything was still ok set up on Jb's dyno 15.7 bhp at about 6500rpm very happy until i read about problems with rapidos.
I was advised to set it at 17 degrees my problem is it now feels down on power.
Would it be ok to put back to 20 degrees and why change the timing weren't they originally set about 23
