Page 1 of 2
Series 2 Ignition Switch?
Posted: Tue Jun 28, 2011 5:39 pm
by soulsurfer
Is it possible to fit a Series 3 Ignition switch to a Series 2 headset?
...or is there such a thing as a Series 2 ignition switch?
Re: Series 2 Ignition Switch?
Posted: Tue Jun 28, 2011 6:04 pm
by Donnie
No such thing as a S2 one, though there was a S2 TV175 switch if i remember right?
but yeah, you can fit a S3 one but why do you want to?
Posted: Tue Jun 28, 2011 6:06 pm
by soulsurfer
I'll have no steering lock and I don't like the idea of being able to just ride it off down the ride, a mild deterrent I know
Would it be a straight fit?
Posted: Tue Jun 28, 2011 6:10 pm
by marburys
Put one in my series 2, only for security and peace of mind, but if someone wants it, it just makes it a bit harder.
Posted: Tue Jun 28, 2011 6:13 pm
by Rich_T
Mike,
Am I missing something? what is wrong with keeping the S2 steering lock and adding a S3 ignition key to replace the S2 cut out switch? Series 3 are the same (different key for steering lock and ignition). The same Li headsets used key ignitions on both the S1 and S2 TV series.
Posted: Tue Jun 28, 2011 6:21 pm
by soulsurfer
Hi Rich, it's a Winter Model headset which has had the steering lock busted off on the inside
Not easy to repair or replace
Posted: Tue Jun 28, 2011 7:00 pm
by Rich_T
Hi Mike,
A series 3 will fit you will just have to work out the wiring / key positions to work with the handle bar switch etc. This will mean a couple of wires being commoned together but that is it.
Posted: Tue Jun 28, 2011 7:08 pm
by RICSPEED
soulsurfer wrote:Hi Rich, it's a Winter Model headset which has had the steering lock busted off on the inside
mike as far as i know s3 key switch will fit but some headsets my need a touch with the dremmel just behind the hole to clear switch ....also do you want me to sort the ally welding for lock area ???
Posted: Wed Jun 29, 2011 12:30 am
by Donnie
yep, i think the non ignition early s3 headsets may need a small bit dremelling out of a bridge inside to fit the ignition switch but you cant see it from outside anyway.
If ricspeed can sort the ally welding for the steering lock id get it done as my s2 has only a killswitch and steering lock, never going to bother with an ignition switch given that it takes less than 10 seconds to bypass anyway
As for wiring if you do go ahead, you need to identify the on off and wire that in and ignore all the rest, that way you don't need to worry about the light switch positions as you are literally only using it as an on off just like the killswitch.
Posted: Wed Jun 29, 2011 12:58 pm
by Doom Patrol
Like Soulsurfer I've got a Spanish S2. I'm not sure if it has been modified at some point because I have what looks like a key operated ignition switch. I've not got around to doing anything with it as yet but it's on and off basically.
