Stud washers
Posted: Sun Jun 26, 2011 6:45 pm
by sydduckett
Anyone care to reccomend the best washers for the chaincase studs. I have oil leaking out a couple of the stud holes so need to get them as sealed as poss. dont have to much thread so nothing to thick.
Ta
sEF
Re: Stud washers
Posted: Sun Jun 26, 2011 7:22 pm
by soulsurfer
The standard wavy washer are the thinnest I've seen, but I'd say your problem extends further than the washers if your threads are stripped.
http://www.scooterrestorations.com/lamb ... vy-washer/
Re: Stud washers
Posted: Sun Jun 26, 2011 9:25 pm
by byron
yes^
you shouldn't be relying on washers to seal the casing.
clean the faces and use a decent gasket, greased before fitting
Re: Stud washers
Posted: Sun Jun 26, 2011 10:09 pm
by sydduckett
ideally id like to get both faces milled properley as they are a bit manky....
