spare wheel / sprint rack mounts
Posted: Sat Jun 25, 2011 6:01 pm
by doggbhoy
where can i get.. decent..
.. rubber washer / spacer to use on inner legshield spare wheel carrier mount and sprint racks ? that helps to not damage the paint...
what are you using?
thanks
Re: spare wheel / sprint rack mounts
Posted: Sat Jun 25, 2011 6:16 pm
by Donnie
I know that Ive used the large legshield rubber washers for this with a metal washer between that and the rack metal before. the metal washer will spread the load on the rubber washer so less likely to split when tightened up.
Posted: Sat Jun 25, 2011 6:32 pm
by soulsurfer
I use tap washers from Screwfix, you may have to drill them out depending on bolt size.
Posted: Tue Jun 28, 2011 10:49 pm
by Doom Patrol
I was going to say 1/2 tap washers. Good for loads of things.
Posted: Thu Jun 30, 2011 8:01 pm
by doggbhoy
ok guys thanks for your help
