How much oil in a P200?
Posted: Mon Jun 20, 2011 7:51 am
by ArmandTanzarian
I know you're just supposed to fill it up until it starts coming out of the filler hole but how much is that?
Having done an oil change, it only took about half a pint (if that) and that seems very little.
Re: How much oil in a P200?
Posted: Mon Jun 20, 2011 8:31 am
by gaz_powell
pg 29 of the vespa dealer service manual states 8.82 oz - 250g but
It goes on to say (which i`m sure you know) put it a level surface and filled it until dribbles from the filler hole.
hope this helps
Posted: Mon Jun 20, 2011 11:51 am
by jet225
I normally put 250-300 ml in the gearbox, using a 'rabbit water bottle', with the ball bearing removed!! This saves the need of getting the scooter on a level surface. Never had any problems with this amount of oil. Put to much in and it can come out of the breather when the scooter is being ridden..!!!
Regards...
Posted: Mon Jun 20, 2011 3:12 pm
by timexit17
Yes, 300ml is enough from completely dry and rebuilt (although you should have soaked the plates 1st of course!)
Posted: Mon Jun 20, 2011 6:24 pm
by Chris.
I've found 250ml to be sufficient.
Thanks for the water bottle tip Jet225 - that'll come in useful!
