p200 floor runners
Posted: Tue Jun 14, 2011 10:55 pm
by Twinny
can someone advise please
fitting some new runners to p2, the kit comes with these rivets,never done vespa,s before,is there a special tool to fix rivets or a hamer job
cheers john
Re: p200 floor runners
Posted: Wed Jun 15, 2011 8:14 am
by gaz_powell
Twinny
i never use the supplied rivets as they are a pain if and when you want them off. Use small ss nuts and bolts/screws with a flat head. I then drill the plastic end caps.
gary
Posted: Wed Jun 15, 2011 11:00 am
by sydduckett
Twinny wrote:can someone advise please
cheers john
Get the hammer out...you know u want to.... :D
Posted: Wed Jun 15, 2011 10:01 pm
by vesbrettas
the rivet the kit comes with are the wrong ones, piaggio use pop rivets all from the top apart from the end caps which are from the bottom i use short 3mm on the runners the 4x10mm on all the end caps apart the two buy the legshield trim which are about
4x13mm hope this helps
Posted: Wed Jun 15, 2011 11:31 pm
by Twinny
thanks for replys (apart from sid bucket lol) i have used nuts and screws but would still like to know if there is a special tool for supplied vespa rivets
thanks
Posted: Fri Jun 17, 2011 6:38 am
by squeakmillward
Twinny wrote:thanks for replys (apart from sid bucket lol) i have used nuts and screws but would still like to know if there is a special tool for supplied vespa rivets
thanks
its not a special tool as such just a normal pop rivet gun fitted with a longer "nozzle" so that it will sit in the runner,available from any tool warehouse
