keeps jumping into gear
Posted: Mon Jun 13, 2011 5:56 pm
by psychedelicropcircle
On the way back from kelso my clutch and gear change got a little stiff. Im heading to the euro in 10 days so i thought I go in and investigate / torque up the vitals. Turns out one of the rivets had worked free in the spider. The bretta paranoia kicked in so I removed the endplate and the gears to see if any of the rivet was rolling around....none to be seen! I have replaced the spider with a racetour one (nae Rivets) put it all back closed up the chaincase popped it on the jack to get it into nuetral to sort out new gear cables and it jumps into a gear as soon as you spin the wheel. I will add it has no gear oil in it at this time.
opinions welcome?
scott.
Re: keeps jumping into gear
Posted: Mon Jun 13, 2011 6:46 pm
by joespeed
psychedelicropcircle wrote:On the way back from kelso my clutch and gear change got a little stiff. Im heading to the euro in 10 days so i thought I go in and investigate / torque up the vitals. Turns out one of the rivets had worked free in the spider. The bretta paranoia kicked in so I removed the endplate and the gears to see if any of the rivet was rolling around....none to be seen! I have replaced the spider with a racetour one (nae Rivets) put it all back closed up the chaincase popped it on the jack to get it into nuetral to sort out new gear cables and it jumps into a gear as soon as you spin the wheel. I will add it has no gear oil in it at this time.
opinions welcome?
scott.
long time ago since i came across this,but you said that you removed the gears to check i sugguest that you have put one cog in wrong get back in there and have a look!
Posted: Thu Jun 16, 2011 8:24 pm
Twas stuck in-between 3-4 gear :oops: would have been :barfy: if I'd have had to pull it back out
