Page 1 of 2
Snapped stainless sterling
Posted: Sun Jun 12, 2011 10:28 pm
by djh66
Went to 'abscond to the pond' today (shame about the weather!) with newly fitted stainless Sterling exhaust on my Li Special. On the way home, I thought Ihad dropped an exhaust nut, as it sounded like it was blowing, on inspection both nuts were good and tight. So I carried on, 1 mile later the exhaust completey sheared off on the u bend!
Although the exhaust was second hand, it appeared to be in almost mint condition, with bearly 300 miles on it.
What is likely to be the cause?
Dave
Re: Snapped stainless sterling
Posted: Sun Jun 12, 2011 10:43 pm
by Knowledge
Personally, I wouldn't build an exhaust for a Lambretta out of stainless steel: it is too brittle. It is very easy, with a the convoluted shape of the Lambretta exhaust, to put strain on the structure of the exhaust which then becomes a weak-spot in brittle SS.
Mild steel, gas welded, rubber mounted with spring slip joint at the barrel and bronze welded backets.
Posted: Mon Jun 13, 2011 8:36 am
by Donnie
:freak: Dave, haven't I warned you off SS exhausts before man? :freak:
Posted: Mon Jun 13, 2011 6:21 pm
by djh66
Donnie wrote::freak: Dave, haven't I warned you off SS exhausts before man? :freak:
Yes, yes, I know, but it looked, sounded great and gave better performnce on the way to Rutland water
Is it possible to get a mild steel u-bend for a Sterling type exhaust Donnie?
Posted: Mon Jun 13, 2011 7:35 pm
by gee
i might have one dave, i'll have a look and let you know
Posted: Mon Jun 13, 2011 7:45 pm
by djh66
gee wrote:i might have one dave, i'll have a look and let you know
Thanks Gee
did you both get home ok?
Posted: Mon Jun 13, 2011 8:06 pm
by gee
Yes mate got home fine (but wet). Bad news is the sterling down pipe was for a vespa but i do have a lammy U-bend but it's 48mm, probably too big but you're welcome to it if it's any good to you.
Posted: Mon Jun 13, 2011 8:32 pm
by Donnie
Im not 100% sure if all the sterling u bends were stainless anyway? I remember they were shiney so either stainless or chromed.
Posted: Mon Jun 13, 2011 9:05 pm
by djh66
Could it have been the stainless getting hot and the rain cooling it, that caused it to snap? There seems to be an awful lot of stainless exhausts out there, without problems.
Just had a closer look and the main part of the exhaust has split aswell, this might have been caused by the exhaust bouncing up and down on the back of the recovery truck. :baddevil:
I'll post some pics. shortly.
Posted: Mon Jun 13, 2011 9:26 pm
by djh66
By
thatnuttysound at 2011-06-13
By
By
