No kickstart - clutch engaged
Posted: Sat Jun 11, 2011 11:48 pm
by BadBob
Just bought a very low mileage px200 engine taken out of a stolen/recovered scooter that had been stored for a couple of years. Kickstart does not engage, just feels as if the clutch is pulled in even though cable is obviously disconnected.
Any ideas what the problem is here?
Cheers
Rob
Re: No kickstart - clutch engaged
Posted: Sun Jun 12, 2011 6:59 pm
by ducksta
are you sure the teeth on the kick start arnt smoothed off it happend to me once and it felt like clutch was stuck in
Posted: Sun Jun 12, 2011 8:47 pm
by H,POOL GADGE
Hole in the piston.....
Posted: Wed Jun 15, 2011 9:39 pm
by wack 63
Clutch woodruff key,circlip off clutch,clutch siezed or missing
Does the piston move?
Posted: Fri Jun 17, 2011 11:00 pm
by BadBob
Cheers for the answers so far. Piston/flywheel doesn't move & kickstart mechanism all seems to be working fine. I think it's got to be something internal and need to look. Woodruff key/ clutch seize looks most likely at the moment I think.
Posted: Mon Jun 27, 2011 1:39 pm
by fraserp200e
BadBob wrote:Cheers for the answers so far. Piston/flywheel doesn't move & kickstart mechanism all seems to be working fine. I think it's got to be something internal and need to look. Woodruff key/ clutch seize looks most likely at the moment I think.
I've had this happen to me - it turned out to be the circlip on the clutch basket had sprung out.......it's worth checking that first as it's a relatively quick fix.
