Gearing recommendations
Posted: Sat Jun 11, 2011 11:17 am
by des
What be the best front and rear sprocket recommendation running with a dl125 gear box and a 186 Imola kit, would i be ok to leave as is, carb will be a 30mm PWK and the pipe will be a standard club man till funds premit something better.
Re: Gearing recommendations
Posted: Sat Jun 11, 2011 1:13 pm
by storkfoot
47/18 will give you GP200 gearing on the GP125 gearbox. This was good on my old Mugello 186, 28mm carb, with a PM expansion (and before that an AF Clubman), so I'm guessing it would be good on your set up now and with an expansion pipe.
Posted: Mon Jun 13, 2011 5:51 pm
by des
Thanks for that, would i need to replace the existing chain with a longer one.
Posted: Mon Jun 13, 2011 7:46 pm
by storkfoot
Yes, you'll need an 82 link.
Posted: Mon Jun 13, 2011 7:51 pm
by Lamaddict
Unsure of the Imola power etc but I like that gearbox running on 19X46 on tuned Stage 4 barrels.
Posted: Tue Jun 14, 2011 6:41 am
by Toddy
des wrote:What be the best front and rear sprocket recommendation running with a dl125 gear box and a 186 Imola kit, would i be ok to leave as is, carb will be a 30mm PWK and the pipe will be a standard club man till funds premit something better.
Choosing Gearing depends on what type of person or riding you do ie small /med / large build ,one up /two up, touring , tootling @ Town , loaded up with bags etc just throw them into the eqaution before you decide mate
Posted: Tue Jun 14, 2011 8:44 am
by des
medium build, never two up usually travel as fast as the bike permits, rearly loaded with bags, just want gearing that will get the best out of the imola kit.
Posted: Tue Jun 14, 2011 1:03 pm
by corrado
Don't go any taller than 5.2 with an Imola or you'll kill it's ability to rev. Mind you so will a clubman
5.4 will be more fun with a revvy / race exhaust..
