hi running a stage 5 200 with 28mm pwk carb anybody using one with a filter if so what sort
cant find much info about them thanks .
air filters
If your running a pwk then i think mb developements do a good filter kit to fit. Give them a ring. Just seen that you have a stage five and thought i'd add that if you have a lot of spit back a filter may make it "burble and stutter" at low revs even with re-jetting.
Hope this helps.
Pete
Hope this helps.
Pete
nuttyboy
- Main scooter: lambretta
nuttyboy wrote:hi running a stage 5 200 with 28mm pwk carb anybody using one with a filter if so what sort
running with mb filter that sticks to panel .yes its proving a pain to jet.runs better without filter .just wondered if any other options
cheers .
This is the kit from MB that i was on about MBU0426 (part number). It's not the one that sticks to the panel. Dont know if in your situation it will fit under the panel. Maybe worth giving them a call?
