air filters
Posted: Thu Jun 09, 2011 9:03 pm
by nuttyboy
hi running a stage 5 200 with 28mm pwk carb anybody using one with a filter if so what sort
cant find much info about them thanks .
Re: air filters
Posted: Thu Jun 09, 2011 9:49 pm
by storkfoot
Through panel, or on an elbow?
Re: air filters
Posted: Fri Jun 10, 2011 9:03 am
by nelson pk
If your running a pwk then i think mb developements do a good filter kit to fit. Give them a ring. Just seen that you have a stage five and thought i'd add that if you have a lot of spit back a filter may make it "burble and stutter" at low revs even with re-jetting.
Hope this helps.
Pete
Re: air filters
Posted: Sat Jun 11, 2011 10:31 am
by nuttyboy
nuttyboy wrote:hi running a stage 5 200 with 28mm pwk carb anybody using one with a filter if so what sort
running with mb filter that sticks to panel .yes its proving a pain to jet.runs better without filter .just wondered if any other options
cheers .
Re: air filters
Posted: Sat Jun 11, 2011 11:14 am
by nelson pk
This is the kit from MB that i was on about MBU0426 (part number). It's not the one that sticks to the panel. Dont know if in your situation it will fit under the panel. Maybe worth giving them a call?
Re: air filters
Posted: Sat Jun 11, 2011 1:27 pm
by storkfoot
I eventually managed to jet a PWK28 more or less correctly but only after cutting a hole in the panel and sticking a Ram Air filter directly on the carb.
