Page 1 of 2
TS1 Ron Moss Ts1
Posted: Sun Jun 05, 2011 7:06 pm
by shedboy
Hi guys
Is any one ruining a Ts1 with a Ron Moss clubman what gear box are you using.I have li 150 17x46 giving me 4.6 but it is hard work in 4th all right on the strait but struggles into wind ore up hill i am not a small lad 17stone any help would be great
thanks shedboy
Re: TS1 Ron Moss Ts1
Posted: Sun Jun 05, 2011 7:14 pm
by bsso78
"Ruining" a TS1 with a Clubman?
Sorry mate couldnt resist that one
Posted: Sun Jun 05, 2011 7:36 pm
by davidblythe
do a straight swap with a LI 125 box to give a ratio of 5.00 on the same sprockets
friend runs the same set up and it does 80mph gps speed
Posted: Sun Jun 05, 2011 7:44 pm
by Chris CSPE
Look in the 'Dyno graph posting area' there's one there.
Posted: Sun Jun 05, 2011 10:19 pm
by Muttley McLadd
A few salads would be cheaper than anything else
Is the barrel untouched? A few hours in the hands of an adult with a dremmel would liberate enough power to pull that gearing.
Posted: Sun Jun 05, 2011 10:39 pm
by tha83
Muttley McLadd wrote:A few salads would be cheaper than anything else
I always thought a dremel would be undermatched to the nicasil lining, no? I've used a dremel for case porting and intakes but shy away from the hard stuff.
Posted: Mon Jun 06, 2011 12:50 am
by Muttley McLadd
Or the professional equivalent. I've not got mine together yet.. but it was fettled by an adult for a couple of days (mild porting). I'm expecting it to pull 4.6 (or higher) with my clubman on, two up. My previous one pulled it, two up, with a DJ pipe on - and that was a similar tune and a chubby lass.
Posted: Mon Jun 06, 2011 11:37 am
by willwander
bsso78 wrote:"Ruining" a TS1 with a Clubman?
grin
Posted: Mon Jun 06, 2011 11:52 am
by Diablo
Yeah have a look in the dyno posts and you'll find Doms TS1. He pulls 4.8 with that and is very happy with it.
I rode it and thought that it was great but wouldn't pull taller than that.
The thing to remember is that the Ron Moss pipes just rev on and on so in my view I think the earlier suggestion of running final drive of 5.0 is good.
BTW I've seen a lot of TS1s on the dyno with expansions on that made less power.
Posted: Mon Jun 06, 2011 3:40 pm
by mickdale
shedboy wrote:Hi guys
thanks shedboy
yes m8
got 60mm crank and 1.5mm machined from the base
runs i ndian gp with 20/47 (4.7) no worries
