TM24 carb and Marchald filter
Posted: Sun Jun 05, 2011 5:37 pm
I notice reading various forums that some are using TM24 carbs with Marchald filters. They come with various adaptor inserts to suit different carb bell mouth sizes. However, the smallest is 46mm diameter while the TM24 is 44mm diameter.
So, when this combination is used are they just tightened up to compress the assembly down onto the bell mouth, or are smaller adaptors available?
Grateful as usual for any response
Cheers,
Nigel
Cheers,
Nigel
