Runner 125 electrical connections
Posted: Sat Jun 04, 2011 12:41 pm
by Ivan Dobski
Anyone know where these connect to? Male/female connectors but doesnt look as if they join together might be the poblem why I cant get it to fire up.
Re: Runner 125 electrical connections
Posted: Sat Jun 04, 2011 1:45 pm
by Ivan Dobski
Forgot to add these are for the auto choke on the standard carb do I need to connect them to anything else or just leve them as is and zip tie them out the way?
Posted: Sat Jun 04, 2011 6:26 pm
by RICSPEED
dont think that will make any difference but you could try connecting to old carb(not fit to scoot though)just to rule it out ...is it 2 or 4 st?
Posted: Sat Jun 04, 2011 9:31 pm
by rondon
ooh ya fecker if it's a 4t prepare for a feckin headache , I've got one that's been twisting me for a while now ( it keeps getting pushed under it's tree at the bottom of me garden for a few month then try again) if & that's a massive IF I make another 4t autovespa I will just buy a complete 4t auto & transplant the full motor wiring etc & if poss I'll have the motor running while I do it
Posted: Sun Jun 05, 2011 8:38 am
by Ivan Dobski
its a 2 stroke think I know what the problem is. Either down to the starter motor or the cable feeding it. Any ideas on what to check I've got a spare motor and lead. Can't kick it over as kick start is goosed but plenty of compression so close to getting it fired Tub grrrr
Posted: Sun Jun 05, 2011 11:23 am
by RICSPEED
it could be the brake light switch ,if thats nacked it wont turn over
Posted: Sun Jun 05, 2011 1:49 pm
by Ivan Dobski
Won't be that was working ok unless it shares the same relay as the starter motor
Posted: Sun Jun 05, 2011 2:55 pm
by RICSPEED
Ivan Dobski wrote:Won't be that was working ok unless it shares the same relay as the starter motor
the starter circuit on most autos is wired in the the rear brake as a safty feature ,if stop swich is not working starter wont turn (or if you dont pull the rear brake as you hit the button)
