Rapido 225
whonatic
Hello people!
Just built a rapido 225 with a 48mm af clubman and a 30mm phbh through a ramair filter.
Just got it running, but it stalls when you try to move off.
What would be the starting point jetting / needle / needle jet/ clip etc?
Paul
Do you mean when you put I'n gear? If so it"s probably clutch drag
Stokie
Ask Knowledge
he may hold the answer ................ :wink:
Daysofspeed
Playstation gamer tag: Daysofspeed
Main scooter: GP225/Rally200
Gear cables wrong way around!
Up The Boro
Can I be the third one to say gear cables?
CANbus
Isn’t there a neutral position in between 3rd and 4th gear?
11111111 = 0xFF
    Users browsing this forum: Baidu [Spider] and 10 guests
