Rapido 225
Posted: Thu Jun 02, 2011 2:15 pm
by whonatic
Hello people!
Just built a rapido 225 with a 48mm af clubman and a 30mm phbh through a ramair filter.
Just got it running, but it stalls when you try to move off.
What would be the starting point jetting / needle / needle jet/ clip etc?
Paul
Re: Rapido 225
Posted: Thu Jun 02, 2011 2:40 pm
by coaster
Do you mean when you put I'n gear? If so it"s probably clutch drag
Re: Rapido 225
Posted: Thu Jun 02, 2011 6:22 pm
by Stokie
Ask Knowledge
he may hold the answer ................ :wink:
Re: Rapido 225
Posted: Fri Jun 03, 2011 6:38 am
by Daysofspeed
Gear cables wrong way around!
Re: Rapido 225
Posted: Fri Jun 03, 2011 7:15 am
by Muttley McLadd
Can I be the third one to say gear cables?
Re: Rapido 225
Posted: Fri Jun 03, 2011 7:23 am
by CANbus
Isn’t there a neutral position in between 3rd and 4th gear?
