Replacement for RS Clubman
Posted: Mon Mar 16, 2009 11:23 pm
by mawso
Hello
I've just bought a GP with an RS tuned engine and RS Clubman (non VW tailpipe). I know this engine pulled extremely well, although, I'm yet to have it running due to a partial strip and rebuild. These pipes perform really well, but I prefer the appearance of an expansion pipe...which will also fit in with the style of this bike. The spec of the engine is Suzuki RS 190, RD400 rodded crank, TV175 gearing, 28mm solid mount Dellorto (going to be changed to a rubber mounted 28mm TM) & Vespa Electronic conversion.
What expansion has the same characteristic performance as the RS Clubman, that would pull this gearing and work well with this engine?
Thanks Stu
Re: Replacement for RS Clubman
Posted: Tue Mar 17, 2009 8:02 pm
by mawso
Ok, alternatively then...Does anyone know what the RS Clubman revs onto?
I'll hopefully then be able to make a choice from: JL Road, Taffspeed MK4, Devtour/Revtour or 80's Fresco / Micron for the above set up
Cheers Stu
