Cutting out..
a.j
Hi, my Lammie runs along ok if I keep the choke out but cuts out otherwise, repeatedly..
Help!!
a.j
ANYONE?????
Fireman Ash
Have you stripped your carb and checked any of the jets for blockage? what size and type of carb is it?
pilot jet blocked............?
a.j
dell orto 22mm
I'm gonna try the above tomorrow
thanks
steve.earby
as a matter of interest how would you unblock the jets does this require stripping down your carb or is there an easy way
dapper
Carb off and strip down carefully. DO NOT use anything other than carb cleaner and compressed air to blow through your jets or you could damage them. Clean everything thoroughly, and replace exactly as the jets came out. Do not overtighten.
