110 rod crank
Posted: Sat May 28, 2011 11:07 pm
by wack 63
Does anyone do a 58/110 good quality crank,not a mega expensive one though?
Re: 110 rod crank
Posted: Sun May 29, 2011 5:09 pm
by grimspeed
BGM !
Re: 110 rod crank
Posted: Sun May 29, 2011 6:30 pm
by corrado
BGM cranks are a myth, I've never seen scooter-center have one of any description in stock. I'd imagine that MEC make them, I've had a 60 x 110 Mec crank.
Re: 110 rod crank
Posted: Sun May 29, 2011 9:30 pm
by wack 63
Thanks Martin I was going to contact you just incase you had one but after searching all the dealers all the 110 rod ones are 60 stroke and my motor is all set up for 58.Will be having my crank welded for now.
Re: 110 rod crank
Posted: Mon May 30, 2011 2:11 pm
by corrado
Grampians in Liverpool will put a 110 rod in a SIL GP crank, but you really need the web faces maching slightly first.
Harry Barlow will re rod a crank for you too.
Re: 110 rod crank
Posted: Tue May 31, 2011 8:38 am
by eibargum
Chiselspeed will also put you a 110 yam rod in SIL webs if you cant get what you want.
Re: 110 rod crank
Posted: Tue May 31, 2011 10:11 pm
by wack 63
Thanks chaps I have now got sorted :)
