Rear brake shoes?
Posted: Sat May 28, 2011 3:51 pm
by lammer205
Hello, is there a easy (visual) way of telling the difference between LI and GP brake shoes? cheers
Re: Rear brake shoes?
Posted: Sat May 28, 2011 4:32 pm
by dapper
The difference in the size of the heel that rests on the cam. IE. thick cam thin heel and vice versa. My Injun Vijai had shims and flat springs under the heel too. If you use a thick cam and thick heels, you won't even get the hub on. A smear of copper grease on the pivot pins and also on the cam for smooth action.
Posted: Sat May 28, 2011 5:22 pm
by lammer205
Sorted, cheers fella.
Posted: Mon May 30, 2011 11:58 am
by desi
If you have a GP hub fitted to an Li, do you need to fit GP shoes?
Posted: Mon May 30, 2011 1:08 pm
by dapper
No, its the size of the cam and the thickness of the heels on the shoes.
