166 exhaust
vesparox
greetings... 8-)
i'm gonna buy a new exhaust for my vespa sprint v....my setup is malossi 166 kit ,20/67 gearing, spaco 2626.
so i really need help from u guys to give any suggestions for my new exhaust..i will need an exhaust for a highway ride...
scootrs,jl rh,jl lh, and pm exhaust..which one is the most suitable for higway ride and give more top end...
gadgetman
JL right hand will give you the torque you need for overtaking and riding up hills at 50 - 70 mph plus makes changing a wheel/tyre much much easier. Ive got one on a GL with Quattrini 172M1XL after having a Sterling on and it has transformed it
vesparox
gadgetman wrote:JL right hand will give you the torque you need for overtaking and riding up hills at 50 - 70 mph plus makes changing a wheel/tyre much much easier. Ive got one on a GL with Quattrini 172M1XL after having a Sterling on and it has transformed it
thanks man for the reply..my previous right hand exhaust hit my righr cowl..so i decided to have jl left hand...will it suitable with my malossi 166 ???i want to have a stable motor with no vibration at high speed on a long run in a highway...sorry for the noob questions.....i'm a newbie....
wack 63
Main scooter: '71 GP TS1
The Scorpion pipe works well on a 166 ,not too revvy and pulls well.
gadgetman
Should be no clearence issues with JL right hander and cowl but on older vespas you may need to modify the stand slightly on one side , ie the bit that touches the frame when the stand is up ,as it hits the exhaust each time the stand is moved
