166 exhaust
Posted: Tue May 24, 2011 8:12 pm
by vesparox
greetings... 8-)
i'm gonna buy a new exhaust for my vespa sprint v....my setup is malossi 166 kit ,20/67 gearing, spaco 2626.
so i really need help from u guys to give any suggestions for my new exhaust..i will need an exhaust for a highway ride...
scootrs,jl rh,jl lh, and pm exhaust..which one is the most suitable for higway ride and give more top end...
Re: 166 exhaust
Posted: Wed May 25, 2011 7:24 pm
by gadgetman
JL right hand will give you the torque you need for overtaking and riding up hills at 50 - 70 mph plus makes changing a wheel/tyre much much easier. Ive got one on a GL with Quattrini 172M1XL after having a Sterling on and it has transformed it
Re: 166 exhaust
Posted: Sat May 28, 2011 2:37 pm
by vesparox
gadgetman wrote:JL right hand will give you the torque you need for overtaking and riding up hills at 50 - 70 mph plus makes changing a wheel/tyre much much easier. Ive got one on a GL with Quattrini 172M1XL after having a Sterling on and it has transformed it
thanks man for the reply..my previous right hand exhaust hit my righr cowl..so i decided to have jl left hand...will it suitable with my malossi 166 ???i want to have a stable motor with no vibration at high speed on a long run in a highway...sorry for the noob questions.....i'm a newbie....
Re: 166 exhaust
Posted: Sun May 29, 2011 9:54 pm
by wack 63
The Scorpion pipe works well on a 166 ,not too revvy and pulls well.
Re: 166 exhaust
Posted: Mon May 30, 2011 11:59 am
by gadgetman
Should be no clearence issues with JL right hander and cowl but on older vespas you may need to modify the stand slightly on one side , ie the bit that touches the frame when the stand is up ,as it hits the exhaust each time the stand is moved
