Cutting out..
Posted: Mon Mar 16, 2009 1:35 pm
by a.j
Hi, my Lammie runs along ok if I keep the choke out but cuts out otherwise, repeatedly..
Help!!
Re: Cutting out..
Posted: Mon Mar 16, 2009 6:31 pm
by a.j
ANYONE?????
Re: Cutting out..
Posted: Mon Mar 16, 2009 8:15 pm
by Fireman Ash
Have you stripped your carb and checked any of the jets for blockage? what size and type of carb is it?
Re: Cutting out..
Posted: Mon Mar 16, 2009 8:16 pm
by sean brady scooters
pilot jet blocked............?
Re: Cutting out..
Posted: Tue Mar 17, 2009 2:05 pm
by a.j
dell orto 22mm
I'm gonna try the above tomorrow
thanks
Re: Cutting out..
Posted: Tue Mar 17, 2009 2:30 pm
by steve.earby
as a matter of interest how would you unblock the jets does this require stripping down your carb or is there an easy way
Re: Cutting out..
Posted: Tue Mar 17, 2009 2:59 pm
by dapper
Carb off and strip down carefully. DO NOT use anything other than carb cleaner and compressed air to blow through your jets or you could damage them. Clean everything thoroughly, and replace exactly as the jets came out. Do not overtighten.
