Piston & Head Damage (Detonation???)
Posted: Sat May 14, 2011 8:49 pm
I have recently bought a complete engine which i knew was suffering from a plug eating disorder. I got it for a fair price and had rode it before i bought it, it ran like a dream lots of power plenty of torque just kept pulling, and it sounded crisp.
Spec
Mugello 225 Cylinder (Touring Tune) 238.63cc
Asso 70mm Piston
Chiselspeed Modified Head
Casings/Manifolds matched to cylinder
62mm Full Circle Crank - 107mm Rod
GP200 Gear Box
19x46 Sprockets
12v Electronic Ignition
BGM 80 Watt Stator
Italian Regulator
Ducati CDI Unit
Ancillotti Exhaust
6 Plate Clutch
Dellorto PHBH 30mm Carb
Ram Air Filter
The plan was to drop it in my GP to see if i could iron out the plug issue. I read up on the possible causes ,Poor ignition,over heating,wrong plug temp and detonation. I decided to check the obvious fly wheel rubbing pickup and dodgy stator wires. When i rotated the fly wheel i noticed some resistance at TDC, pulled the fly wheel of expecting to evidence of the fly wheel rubbing something....nothing. i rotated the crank by hand and notice the resistance was still there.
Head off time.....now I've read a little about the causes of detonation but i never expected to see this
The bore looks ok put is polished in places,
So hows this happened, whats the cause and more importantly how would you set up the replacement head.
Any suggestions and thoughts will be appreciated
Jay
Spec
Asso 70mm Piston
GP200 Gear Box
19x46 Sprockets
BGM 80 Watt Stator
Italian Regulator
Ducati CDI Unit
Ancillotti Exhaust
6 Plate Clutch
Ram Air Filter
Jay
