chrome ring head or not
Posted: Thu May 12, 2011 8:41 am
Can you add a non chrome ring head set to a chrome ring bike by taking a bit off the bottom of the head set - or is the stearing lock in the wrong place etc--
There the same apart from there is more meat below the steering lock on a non chrome ring. You can machine it off but its hassle as the front of the headset intrudes into the base of the bottom headset.boxofbits wrote:how can you tell the diffrance between headsets is it just 9mm or
something
It's rather easier to remove the chrome ring and replace the top bearing. If you care about having a steering lock, it just means welding a small piece of steel on the fork tube.boxofbits wrote:Can you add a non chrome ring head set to a chrome ring bike by taking a bit off the bottom of the head set - or is the stearing lock in the wrong place etc--
