extended engine mounts
Posted: Tue May 10, 2011 9:32 pm
by sjc
has anyone had problems with andy francis extended engine mount rubbing on there side panels,,many thanks steve..
Re: extended engine mounts
Posted: Tue May 10, 2011 9:33 pm
by mark
none on my gp or series 1, have you?
Posted: Tue May 10, 2011 9:37 pm
by sjc
just gave my mate my spare on for his jet 200 and its rubbing the side panel...
Posted: Tue May 10, 2011 9:38 pm
by mark
he is only using the half nut on the kicksatrt side isnt he
Posted: Tue May 10, 2011 9:40 pm
by sjc
yes mark,,hes even machined the nut down a bit more...
Posted: Tue May 10, 2011 9:52 pm
by mark
thats strange are they sx panels? as these are a fraction thinner where the front flashes are fitted to panel
Posted: Tue May 10, 2011 10:22 pm
by Bilko
I had mine rubbing the side panel on my GP. Mine came from Taffspeed
Posted: Tue May 10, 2011 10:48 pm
by mickdale
they are 70s LI style panels
the stud fouled the panel (was proud of the rubber panel buffer)
wound down the half nut on the shorter thread to the end, then put in a lathe and turned down the stud and half nut a couple of mil to shorten.
still touched panel so took about 4mm from the mount.
will fit under the panel now.
havent a clue why but problem now solved
Posted: Wed May 11, 2011 7:22 am
by mark
Have you let Andy francis know as I'm sure he would Like to know of problems with his stock so he can investigate it
