Cosa Clutch kit for P2
ArmandTanzarian
Hello all.
The clutch in my P2 engine is rubbish. The adjustment between dragging and slipping is about 0.00001mm. Are all Cosa clutch kits much of a muchness or does the quality differ? If I'm going to go to the bother of getting one and fitting it, then I might as well get a good one. (The engine is more or less standard and so power shouldn't be an issue.)
Any recommendations as to where to get one.
please just do a search on here as weve covered this subject many times ...and all is explained as to how to modify your clutch to work properly ...in fact it comes up SO many times that we should i think make it a sticky lol
gaz_powell
i`ve had a genuine cosa clutch in my tuned p2 for years and never had any issue with it. It went straight in from purchase and worked correctly and felt loads better than the old type.
i rebuilt the engine last month and stripped it - the corks/metals and springs were still in good good nick and didnt need changing however as part of the build i did.....they ended up in another clutch working fine as a Thursday before rally emergency repair
problem is there are loads of pattern ones about.
ArmandTanzarian
I've just bought what was advertised as a genuine Piaggio part. It should arrive in time for fitting over the weekend.
    Users browsing this forum: No registered users and 66 guests
