offcenter scootrs outboard disc brake kit
Posted: Sun May 08, 2011 3:54 am
by Robi D
I've got a scootrs kit and one side is 1 inch to the fork leg the other side 1.5 inches the fork leg. What causes this? Is there a way to fix this?
Re: offcenter scootrs outboard disc brake kit
Posted: Sun May 08, 2011 6:44 am
by soulsurfer
Posted: Sun May 08, 2011 9:05 am
by 10 inch Terror
Have you had any damper mounts welded to you links? I had the same problem with both a Scootrs and LTH brake. It turned out to be due to my links warping when i had damper mounts welded on them.
Posted: Mon May 09, 2011 5:13 am
by Robi D
No, just have bolt on brackets! Thought about eelding them up, I even made a jig for it.
Posted: Mon May 09, 2011 5:49 am
by Robi D
Wow! That was some of the most retarded crap I have ever read!! I don't really even remember if my question was answered! :shock:
Posted: Mon May 09, 2011 6:52 am
by soulsurfer
Robi D wrote:Wow! That was some of the most retarded crap I have ever read!! I don't really even remember if my question was answered! :shock:
Well use the search button some more, this subject has been brought up several times before.
Posted: Mon May 09, 2011 7:06 pm
by 10 inch Terror
Nice cheers.
Posted: Mon May 09, 2011 7:39 pm
by ArmandTanzarian
I assume you're referring to the other thread. Unfortunately any post containing the word "ScootRS" is obliged to degenerate into abuse within 10 contributions. Apparently its a forum rule.
