Drop bars
RBG
Has anybody else had a problem fitting Scooter RS Drop bars?
If so did you need to grind down the steering lock that sticks out the bottom of the headset
so it clears the little welded on lug on a S3 frame?
Thanks.
but its far easier to just file the lug on the frame :D
RBG
sean brady scooters wrote:but its far easier to just file the lug on the frame :D
:shock: This would be true. However Its done now :lol:
Have dremel will grind.
