GEAR RATIO
Posted: Fri May 06, 2011 1:09 am
by roy242
hi all!
I have to buy clutch for my lambretta TV175 S2 ... she will be equipped with Mugello 185, dellorto 30MM and expansion exhaust scootrs.
could someone tell me what gear ratio would have to put to use as a tourist?
thanks!!
Re: GEAR RATIO
Posted: Fri May 06, 2011 7:09 pm
by shanetv175
leave as is
Re: GEAR RATIO
Posted: Sat May 07, 2011 12:34 am
by roy242
shanetv175 wrote:leave as is
46/15?
Re: GEAR RATIO
Posted: Sat May 07, 2011 7:52 pm
by shanetv175
yep
Re: GEAR RATIO
Posted: Sat May 07, 2011 8:48 pm
by mawso
Roy if you haven't already bought the ScootRS expansion...you might want to choose the Series 1/Series 2 ScootRS expansion which has a slightly longer end pipe before it reaches the tailcan. These are supposed to give more torque than the Series 3 version, which would suit you for touring and better bottom end power on hills, etc.
Re: GEAR RATIO
Posted: Sat May 07, 2011 11:21 pm
by roy242
mawso wrote:Roy if you haven't already bought the ScootRS expansion...you might want to choose the Series 1/Series 2 ScootRS expansion which has a slightly longer end pipe before it reaches the tailcan. These are supposed to give more torque than the Series 3 version, which would suit you for touring and better bottom end power on hills, etc.
yes, I bought the version for eh series 1 and 2.
