Clutch slipping
Posted: Wed May 04, 2011 9:48 pm
by marburys
Hi out on my series 2 with sil gp 200 in yesterday, notice clutch slipping when i was doing 55ish any help would be greatly received. thanks in advance
Re: Clutch slipping
Posted: Wed May 04, 2011 9:50 pm
by mark
what clutch you running 4 plate,5 plate 6 plate,corks ,greens,red plates ,1mm,1.2mm 1.5 mm steels how thick is your top plate? what oil?what springs?how many miles has it done?
if its a std 200 its probaly a 4 plate cork with 1.5mm steels in st90 with std springs . the easiest way to upgrade it is put some stronger springs in which are available from most dealers and then see how it goes
