uncontrolable revs!
Posted: Fri Apr 29, 2011 8:32 pm
by marteibar
I have just re-built my LI150 engine and am now running it in, after riding it for a couple of miles when i engauge neutral it revs its nuts off and i have to turn the engine off!
Any ideas please.
Re: uncontrolable revs!
Posted: Fri Apr 29, 2011 9:11 pm
by bristolmod
1) Throttle cable snagging somewhere, or, more likely
2) air leak when warm (inlet manifold; exhaust gasket; head gasket; crank seals)
Chris
Posted: Fri Apr 29, 2011 10:14 pm
by sydduckett
slide in the wrong way...not that iv done that you understand...
Posted: Sat Apr 30, 2011 12:11 pm
by marteibar
Thanks guys, i'll check for an air leak, my slide is in the correct way, i can't believe any one would put it in the wrong way! lol.
Posted: Sat May 07, 2011 1:17 pm
by marteibar
All sorted now and running well!
Posted: Sat May 07, 2011 2:55 pm
by Bofs
What was it?
Posted: Mon May 09, 2011 10:31 am
by marteibar
Hi Bofs, I had used the wrong gasket sealant, i used the red hermatite stuff and not the Blue high temp silicone sealant.
Posted: Mon May 09, 2011 7:43 pm
by bristolmod
? that won't affect it
Posted: Tue May 10, 2011 10:13 am
by marteibar
All i know is that it's done the trick, although the cylinder bolts could have been a bit tighter!
Mart
